Wolverine & the Mikuni TM36-2 Carb
Has anyone installed this carb on their Wolverine or Warrior. I'm running into a small problem finding the proper cable. I've been told that the Mikuni VM36 cable from Motion Pro will work. Motion Pro lists a cable for this carb under the Honda Performance Cables but not for the Yamaha. Would the cable for a stock Honda 250r and this carb work with my Wolverine or would I have to install a Honda throttle? Also what needle/position/main jet are you running?
Thanks in advance!!!!
Whirli
99' Wolverine
Wiseco 10.25 Pistion
Supertrapp IDS Exhaust
White Bros High Rev Cam & Spring Kit
K&N Filter & TM36-2 Carb
Whirli
99' Wolverine
