Big bear pivot bolt removal
Old Sep 24, 2010 | 04:05 PM
wvdealz's Avatar
Default Big bear pivot bolt removal
I have what I believe is a 1991 Big Bear 4 x 4 (not sure about the year). I can seem to figure out how to get the swing arm bolts out. There is a nut threaded on the end, which I removed, then the bolt itself if threaded on the outside. On the end is a hex head hole. I put a alum wrench in it and tried to turn it, but just bent my alum wrench with no movement of the bolt. I need to replace my missing swing arm boot, and need these pivot bolts off. Any tips would be appreciated. Thanks
Old Oct 1, 2010 | 06:33 AM
hillbilly_racer's Avatar
Once the nut is loose, the bolt should screw out with the allen wrench. These bolts can be very tight. You may need to get a better allen wrench or use a little heat on the frame. Be sure to put never seize on the bolts when you re-install them.
Ean
Dec 19, 2022 08:48 AM
skeets44
Jul 17, 2015 01:04 PM
Desimation2k8
Jul 17, 2015 12:37 AM
Unzzy66
Jul 11, 2015 10:01 PM
Shifts
Jul 3, 2015 07:59 AM
