Grizzly Problems.
Old Mar 9, 2001 | 05:33 PM
packrat's Avatar
My son put a FMF pipe K&N air filter and jet kit on his grizz now it doesnt have the power it had before. What went wrong? Is the jetting wrong?If so how can you tell other than loss of power?I read somewhere that you could tell by looking at the spark plug that if it wasnt burning white then the jet wasnt right,is this true?The pipe has plates on the back to adjust restriction of exhaust(all plates are on).Also we've never figured out why it sometimes cuts out going up steep hills at full throttle and dont at half throttle.
Old Mar 9, 2001 | 06:47 PM
Raptorrider2001's Avatar
Just the opposite. The plug porcelain should look tan. When they are lean, they turn white and blister. The cutting out sounds like it is to lean. Check it out soon. It you continue to run it to lean it can burn a hole in a piston or burn a valve.
Old Mar 9, 2001 | 11:34 PM
john2001grizzly's Avatar
You didn't say if your plug was burning white, tan, or black. A spark plug is a great indicator of engine tuning with very light tan as the desired color. As Raptorrider said, too lean and the plug will be white and blistered. Too much fuel and it be black and will foul. Also, if you exhaust is too restrictive, you won't clean the burnt gases from the cylinder and the plug will eventually turn black.
From your description of the engine losing power at high rpm, you problem could be too little fuel or too much exhaust restriction. Remove most of the restrictor plates from the new pipe and give it a few runs (start with a fresh spark plug). If it still doesn't run right, check the color of the plug and adjust the fuel delivery as necessary.
Old Mar 10, 2001 | 12:39 AM
packrat's Avatar
Thanks for help guys, going to try to make it run right this weekend I'll let you know if we find the problem.
Old Mar 10, 2001 | 10:31 PM
packrat's Avatar
John2001grizzly, took old plug out and it was black installed new one rode a short piece took it out and it was also black. The FMF pipe has the restrictor plates on the outside, when they are all on it is wide open isnt it? Tomorrow we are going to clean air filter and adjust air fuel mixture.
Old Mar 11, 2001 | 09:44 AM
Dakota's Avatar
I have a 2001 Grizzly. Every since I've had it when I go up a steep hill it gags. Sometimes it even dies, I have never done anything to to make it run faster or for more power.Saturday when I was riding it died going up a 45* hill, when we pushed it down to the flat creek bottom we could see raw gas floating in the water.
any Ideas?????
Old Mar 11, 2001 | 02:10 PM
bayougrizz's Avatar
packrat,
to get a truely accurate reading of the plug (for jetting) you need to install the new plug, then run the bike up to and at about 3/4 throttle for a few moments and reach over and hit the kill switch while you are still at 3/4 throttle. then stop the bike, pull the plug, and get your accurate reading. you could be running a lean jetting, but then once you bring it back down to idle its running a little rich and making the plug black.
Old Mar 11, 2001 | 11:13 PM
packrat's Avatar
Dakota, this grizz run fine for about 8 months then it started cutting out going up steep hills but on level it ran fine. He put a FMF pipe, K&n airfilter, and jet kit in and it lost power on level ground and still cut out on hills. I dont think the add ons have anything to do with the engine cutting out.Today it was missing and cutting out any time it was full throttle and on hills the engine would quit.If you find your problem let me know.
Old Mar 12, 2001 | 09:37 AM
mudflap's Avatar
Hey,
Grizz owners,
How do you adjust the fuel, air mixture, etc. on a grizzly?
Old Mar 12, 2001 | 03:00 PM
packrat's Avatar
mudflap,in the front of the carb on the bottom there is a screw up inside of a hole. You cant see it unless carb is off but you can get to it with a small straight screwdriver.
