charging
Old Mar 2, 2011 | 02:38 PM
iceman 1140's Avatar
Default charging
have 02 grizzly having some starting problems. believe it is a charging issue. after getting started batt voltage will go up to 13.5 reved up. check volts after riding little while [20min] volts just under 12. no lites on during ride. just ride. leaning toward wiring or stator. was going to test stator not sure which plug, found 3 plugs behind left side cover all white connectors. looking for little help
Old Mar 2, 2011 | 05:55 PM
snow racer's Avatar
Do you have a good batt and how are you starting it now if your jumpstarting it it is a batt if its an acid batt put a lil water in it to top it off and put it on a trickal charge. All that may fix it. Some times you just gotta spend the $ on a battery.
Old Mar 2, 2011 | 06:56 PM
Kerbbirds's Avatar
battery voltage should be 12.5 or higher when shut off, should see 13.5 or higher reved up, as stated maybe bad battery
ReconBayou
Oct 31, 2022 05:37 PM
speedbuff
13
Nov 11, 2020 10:16 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Jersey General
1) Engine problems..
Sep 13, 2015 01:05 PM
zPuls3
Sep 12, 2015 08:54 AM
