98 yamaha big bear 350 2wd rear end fluid
If it has a conventional rear brake/hub
you should see it off to one side near a wheel.
I would assume that you have a solid axle,
so you should have a conventional brake hub.
Newer Yamaha's with rear CV shaft axles will have brakes inside the rear diff.
Hence the name "wet brake" as brakes are bathed in oil inside the rear diff.
Jul 7, 2015 11:00 PM
