What is a secondary clutch??
Old May 9, 2011 | 09:01 PM
Cameron C's Avatar
Default What is a secondary clutch??
Hello, there is this 87 Yamaha Moto 4 225 in great condition, but all it needs is the secondary clutch replaced. Anyone know what that is? Is it like a second clutch??
Old May 9, 2011 | 10:17 PM
tempmaster's Avatar
I am not to familier with that model but what I can tell from parts breakdowns online this model does not have a secondary clutch. My understanding of a secondary clutch would be on a bike with a constant velocity drive system as snowmobiles have. The primary clutch would be directly connected to the engine and would start in the full open position while the secondary is connected to the final drive components (i.e. transfer case, HI/LO selector) and starts in the fully closed position. As the primary clutch is forced closed by the centrifugal force of the spinning weights the secondary is forced open by the force of the belt moving. The unit you are asking about just has a typical semi automatic style clutch that is connected to the gearing system (transmission). So you may just be looking at replacing clutch plates or you could have an issue in the transmission itself. Hope that helps and good luck.
Old May 10, 2011 | 01:59 PM
Cameron C's Avatar
Ok, I emailed the guy selling it, and this is what he said about it: "the clutch plates are new,but the secondary clutch is
worn out and will need to be replaced." Does he mean the primary clutch?
Old May 10, 2011 | 04:14 PM
judas009's Avatar
he could be talking about the centrifugal clutch. those go bad more than anything in your clutching. and depending on the bike could run you 500 in parts to replace because if the centrifugal clutch is bad then most likely the bell housing it catches on is grooved and would need to be replaced too.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
