???!?!?!?!?!?!?!?!? help
Old Jun 22, 2011 | 02:11 PM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
Originally Posted by Greene17
what causes a fourwheeler to randomly drop out of gear without touching the clutch or the shifter
clutch & syncros- do you shift a lot without using the clutch (power shifting?)
Old Jun 22, 2011 | 02:17 PM
Greene17's Avatar
no i dont not usually i have a bit but not much.
Old Jun 22, 2011 | 02:19 PM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
probably have a worn gear box- just pull the clutch basket out and check the all the shifter parts for wear- probably have a few worn gears also. You really need to get a manual and start from step one and work your way into the case if need be.
Old Jun 27, 2011 | 03:37 PM
420Pimp's Avatar
All ways use your clutch bro, thats why its there.
Unless you enjoy taking apart trannys and buying new sh*t.
Good luck man, hope you get it straight.
Old Jun 30, 2011 | 09:49 AM
  #15
gascan22's Avatar
I had a similar problem with my rm 250 so I stripped it down and it turned out to be worn gear dogs. The edges of the dogs were rounded so every now and then under acceleration the gears would pop out of place, going into a false neutral.
Like beergut said you need to get a manual and find out whats going on because if you ignore the problem it will probably end up costing you more in the long run.
