'92 Big Bear 350 gear grinder
Old 07-24-2011, 02:02 AM
Dave S's Avatar
Default '92 Big Bear 350 gear grinder
Dumb Question, or so I think...
Why would the bike sound like gears are grinding when I apply the rear brake? Now this ONLY occurs with the foot pedal, not the hand lever.
Old 07-24-2011, 05:17 AM
atv_rebuilding_passion's Avatar
what kind of transmission do you have, do you have a shaft drive or chain. because if you have a shaft or i guess even with a chain when you apply the brake without pulling in the clutch, and you brake too far the gears might grind but im not sure
Old 07-24-2011, 08:10 AM
TLC's Avatar
TLC
TLC is offline
When dirt and grud gets into the rear brake drum housing it will make a grinding sound, also your brake shoe's liner may be worn off by now and its metal on metal now.
Old 07-25-2011, 09:06 AM
Dave S's Avatar
It's a "semi-auto" trans, with a shaft drive and new pads on the rear.
I guess what throws me for a loop is the hand brake doesn't do it, only the foot brake.
Still searching for more answers!!!!
Eliminated:
Rear diff fluid levels
Transfer case fluid levels
Rear brake thickness
linkage binding
Ean
12-19-2022 08:48 AM
Kodiak-vic
07-29-2015 03:06 AM
Peter_
07-18-2015 07:06 AM
Chuck188
07-17-2015 02:45 PM
Jkfx400P
Sport Quads
07-05-2015 10:33 PM
Quick Reply: '92 Big Bear 350 gear grinder
