'99 beartracker stator problem. Need advice.
Old Dec 29, 2011 | 07:29 AM
skidaddyrickus's Avatar
Question '99 beartracker stator problem. Need advice.
I have a '99 Yamaha Bear Tracker that I think the stator is bad in. It has a spark but the manual says it should jump a 1/4" gap, but it won't jump across a 1/16" gap, much less a quarter. I have tried a new Ignition coil, plug and still the same thing. It has newly rebuilt carb and I know it’s not the issue.
It will not start with the starter, it will only start with the pull rope and idles fine until it warms up. It then starts missing and dies. It won't start again until completely cold. Per the manual I checked the resistance of the stator and found the source coil to be HIGHER than spec. The pick up coil measures OK. I also checked the source coil to ground and it showed to be grounded. Once I removed the stator from the bike the R is still high but no ground condition.
I'm thinking the stator is weak and when it warms up the Resistance is increasing to the point it actually kills the spark. I'm just looking for some confirmation before I shell out the $160 for a new stator.
Also there was a small amount of oil in the stator housing. I think this is normal but needed to ask.
Old Jan 5, 2012 | 10:32 AM
EPI Shawn's Avatar
Dose the source coil have more resistance After the machine has been run and dies than when it is cold?
ultangler
Nov 30, 2024 01:35 AM
Beeline08
Nov 11, 2016 04:00 PM
kodiacrunner
Oct 4, 2015 11:52 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
kbazzy
Sep 26, 2015 11:26 AM
