660 raptor
Old 03-19-2012, 10:43 PM
Ethan Naugle's Avatar
Default 660 raptor
Hi i was wounding if someone could help me on gearing on my 660 raptor. Im going to run 275ft dirt atv drags. it has satge 1 hot cam. stage 3 dg full pipe, drag clutch with 25% stiffer springs i am planing on running 18X10X9 tires i raced there last year and could only get 2nd gear almost 3rd when it was other and i was catching them i was thinkg useing a 11t in the front and 40t in the back what u think? any help would be nice thanks
Old 03-20-2012, 09:46 AM
HMT Racing's Avatar
Do you plan on taking off in second gear??? 11f X 40r X 18" seems really low
Old 03-20-2012, 10:50 AM
I dont really care what gear to start out in i have no probelm missing gears or anything I was told to go to to teeth smaller in the front and leave the back stock stock gears are 13f/40r but I like to also drop a tire size if I can like i said its only 275 ft drags and could'nt get out 2nd
Old 03-21-2012, 08:39 AM
beyondupnorth's Avatar
Originally Posted by Ethan Naugle
I have a 660 raptor with stage 1 hot cams, stage 3 dg full exhaust, with a drag clutch that has 25% stiffer springs. Im going to run 18x10x9 tires. Now what I am wanting to know is what gears would be good for 275ft atv dirt drags. Last year I went and couldn't get out of 2nd gear about the mid range of 2nd I was starting to catching them but the race was over. Now I was told to go 2 teeth less in the front and leave the back stock the stock gears are 13 tooth in the front and 40 in the rear. Hope someone can help me with this bc im not sure what to do lol.
From a old drag racer,
Gearing is hard to predict in your situation. If you knew the rpm you engine was at at the finish line you could calculate where you need to start.
In your case you will have to buy say a 9 and 11 for the front and perhaps a 42 for the rear.
You presently have a 3.08 to 1 reduction in gears
11/40 would give you 3.66 to 1
9/40 would give you 4.44
11/42 = 3.82
9/42= 4.67
Then pick what you want to try first and go test it on a 275ft track
Depending on the dirt and therefore the traction available you may still find something that works good at home or in todays air is still not bang on at the race
Also please don't double post the same topic.
bmxatv10
10-14-2022 06:23 PM
black_thunder
09-22-2015 07:59 PM
Alex Rodak
09-13-2015 12:30 AM
Alex Rodak
09-12-2015 09:39 AM
Alex Rodak
09-11-2015 11:42 PM
Quick Reply: 660 raptor
