BIG problem! Rode someone's Blaster, it died & won't start!
Old May 17, 2012 | 10:10 PM
Nelson's Avatar
i agree with over head
Old May 18, 2012 | 04:14 PM
beastlywarrior228's Avatar
I wanna see how this turned out
Old May 18, 2012 | 04:46 PM
95wolv's Avatar
This is more than likely what happened: they rode the living P%SS out of it, noticed it starting to run funny, then "let" you ride it up and down the road, then point a finger at you and say...innocently..."What did you do to my ATV? , it was fine a minute ago". and now expect you to give them a new motor?. Chances are, they ran the injection tank dry, or forgot to premix the fuel if the injector was removed. At most, the rings are toast or the cylinder is scored, a piston, rings and a hone or bore, a head gasket and base gasket, and you are up and running again, no new engine needed. Don't be rude, but make it clear that you did nothing to cause this, and like you said, they rode it for several miles then handed it to you, so any damage done was already present before you took off.
Old Sep 5, 2015 | 05:49 AM
Matthew Mindblowned Foster's Avatar
Default My blaster
Okay so I have a problem, kinda similar to this situation but I was riding my blaster for a lil minute then it sputters a lil bit but I kept going so I got to a stopping point & started revving & like once it got to its highest rpm it backfired & won't start anymore. I mean it used to do it all the time but it'll kick back on later or try to turn over but this time it gave out & not doing nothing so I'm asking for suggestions. Like all I have done so far was take the old spark plug out & put a new. My gas mixture is right, the carb is clean I guess, I took it off & took it apart but it looked clean. So now I'm sick 😩 & Don't know what to do. I was thinking though maybe I blew a hole in my piston because the last dude that had it didn't keep up with it so I'm guessing he never changed the piston but get back with me ASAP PLEASE & you can even text me if that'll be better 3185289096 my names Matthew or email me retsof.wehttam@yahoo.com
Old Sep 8, 2015 | 04:37 PM
  #15
95wolv's Avatar
If it backfired at high rpm and then quit, it could be you sheared the flywheel key and now its loose and not firing. I would pull the side cover and check the flywheel is lined up on its keyway and the crankshaft keyway. It is possible the piston burnt, but it would have to get pretty hot for that, but a quick compression check should tell you if it is sealing up good or not.
Old Sep 11, 2015 | 01:38 AM
  #16
greg74's Avatar
Doesn't sound like much of a friend. Main reason I never ride anyone else's stuff. I wouldn't pay to fix it. I'd buy it from them instead if they just had to have some money. Fix it and flip it or fix it and ride it yourself. About $200 is a fair price for a blown up blaster I think.
whitty
67
Feb 24, 2021 02:52 PM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
dnm48
Jun 14, 2015 10:11 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
