Finally! Some pictures of my Raptor 350
Yes. That does bug me a lot. I didn't know that steel wool will work on the header. Any cure for the dirty motor? I've try dish soap, car soap, carb cleaner and simply green to remove the dry overdue dirt, but nothing has worked.
some people use a diluted muriatic acid solution- but you have to be very careful as muriatic (hydochloric acid) is a strong corrosive acid and will etch the aluminum- if you're not fimiliar wit how acids work, then you should just stick with the mag wheel cleaners and play it safe
both can be purchased at any home depot or auto parts store.
additionally- you may have good luck trying "CLR" (Calcium Lime Rust remover) which can be found in the grocery store in the bleach / soap aisle- it's used to descale and remove hard stains in sinks, toilets and on most metal suraces. It's cheap & safe to use. Brush it on, let it sit a few minutes and then hose it off. Try iy on a small area first.
good luck!
#15
mag wheel cleaner should work well for that open pore aluminum. Spray it on, let it sit a few minutes and hose it off-
good luck!
good luck!
#17
#19
#20
I used to ride a lot of sport quads before I got into the big 4x4 atv's- the 250 ex has a "sport clutch" no hand clutch required. I forget how many gears it had- but you couldnt stall it no matter what.
My wife drove her 02 250ex for 2 years (until she rolled it down a hill)- we bought it specifically because it didn't have a clutch, she couldn't use a manual clutch- just shift and gas.
08-25-2015 11:16 PM
