FMF combo and not rejetting?
Old Mar 22, 2001 | 10:05 AM
supraman's Avatar
Would it run lean enough to cause damage to the Raptor?
Old Mar 22, 2001 | 12:32 PM
Twinshot's Avatar
When you say combo, do you mean head pipe and silencer? I know my friend put a E-series WB pipe on his Raptor and he did not rejet it.
swytak's Avatar
Have you looked at their website? It gives recommendations for jetting. The recommendations may be off a little, as I found out 6 months ago installing the Power core 4sq slip-on. Their #'s seem to be lean, atleast that's what I experienced.
Good luck!
Old Mar 22, 2001 | 08:50 PM
jetsnow600's Avatar
how much does this pipe help, i am planning on going this saturday to pick up the head pipe and exhaust, i would like to know jetting advice , and is the pipe worth it? Thanks, sean
Old Mar 22, 2001 | 09:20 PM
hot_shoe_cv's Avatar
supraman,
It is an exercise in futility to ask other people with other riding styles and at other elevations what your engine needs. You have to ask your own engine by means of a test & plug read. When I put the Pro Circuit T4 on my Raptor, My plug told me it was lean at stock so I went up two sizes fatter on the main jets. You really have to test your own bike to know, but a lean mix can create excess heat which can result in a scored piston or worse.If you need some help in testing/rejetting, I have written an easy to follow tutorial with a photo of my plug from a properly jetted Warrior. You can email me for it.
One other thing, if a pipe doesn't require fatter jetting, it must mean that it is not increasing air flow and therefore isn't doing its job.
Old Mar 23, 2001 | 12:03 AM
pairof98s's Avatar
The FMF pipes come with 260 main jets and you will need to use them. If you only buy silencers, they will fit your stock pipes with no jetting necessary. No power gain, just different sound. With the Fatty's and a K&N filter, you will need 270 mains.
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
mitchxc700
Aug 19, 2015 02:41 AM
cSchwartz
Jul 9, 2015 02:43 PM
