Yamaha blaster problems
Old Dec 23, 2012 | 08:15 PM
Vbianco0922's Avatar
Default Yamaha blaster problems
I have an 05 blaster can't get it running right when I kick it it doesn't start unless I pin the throttle and when it does start its got no power. It won't move and the engine sounds like a normal idle speed when the throttle is pinned, any ideas on how to fix it or even what's wrong with it I can't figure it out
Old Dec 24, 2012 | 02:47 AM
rjenx's Avatar
Pull the carb and intake boot it sits in and see if the reeds behind the intake are cracked or broken. If not take that carb apart and soak the pieces in gas overnight.
Old Dec 24, 2012 | 07:57 AM
Ok thanks ill give that a shot today the carb looks pretty clean that's what I thought it was at first but I'm gonna clean it real good to rule that out
Old Dec 25, 2012 | 04:08 PM
woodsidewarrior's Avatar
when is the last time you have checked the compression.you may need a top end rebuild
Old Dec 25, 2012 | 05:51 PM
Not sure what compression loss would feel like but the kick start seems to be pretty firm if that makes a difference
skinnyr6
Aug 25, 2023 02:18 AM
Frisky2050
Apr 9, 2020 11:19 AM
toonces
Oct 16, 2019 12:11 PM
Sjrpp
Jun 2, 2019 07:25 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
