A/C OUTLET on KODIAK...
Old Mar 23, 2001 | 09:09 PM
JHAM's Avatar
Tried to use the A/C jack for a small air compressor and it wouldn't work on my 00 Kodiak. I had the key on and started etc. It used to work but haven't used it in awhile, you guys may want to check yours. Any ideas on a simple fix? Appreciate any info. given.
2000 Kodiak 4x4
2000 Warn winch
Escavators
1995 Kodiak 4x4
2000 Warn winch
Old Mar 23, 2001 | 09:42 PM
Kodiaky2k1's Avatar
Your a/c outlet is hooked up to a 10 amp fuse under your seat. Check for voltage at the outlet if none check the fuse. Mine blew with just utility light, I use for plowing.--The fuse is a mini atc fuse(plastic push-in) any autoparts store has them.
Old Mar 24, 2001 | 09:16 AM
JHAM's Avatar
I was hoping that's what it is. I'll have to check it... THXS.
TLDPredator
May 28, 2003 01:16 AM
Roofer
Feb 11, 2003 12:35 AM
WannaVinson
Jan 17, 2003 02:17 PM
AZSAND
Jan 3, 2003 11:44 AM
