85 moto 4 yfm200 rough running
Old Apr 2, 2013 | 09:30 PM
ksoden1's Avatar
Default 85 moto 4 yfm200 rough running
I recently acquired 1985 yfm 200. Choke cable was broke and fuel filter was in backwards when I got it. I have since replaced choke cable and turned fuel filter the right way, changed oil and filter, and replaced spark plug. When cold it seems to run rough and backfire. Once it warms up it runs good. It seems like the longer it runs the better it runs. Any advice on what is causing my rough run is greatly appreciated.
Old Apr 4, 2013 | 10:12 AM
95wolv's Avatar
I would check your valve clearance, could be too tight, then when it warms up, everthing expands and gets withing spec. too tight will not allow full valve opening which would make it run bad when cold.
SOLOLUCKY
Oct 4, 2024 09:09 PM
tylerhenson25
Ask the Editor
May 11, 2017 07:04 AM
wannabe32
Jul 7, 2015 11:30 AM
jayking232003
Jun 9, 2015 02:54 PM
tylerhenson25
Ask the Editor
Jun 7, 2015 08:53 AM
