shifting from low to high
Old Apr 8, 2013 | 11:18 AM
yamaha1990's Avatar
Default shifting from low to high
someone gave me a 1990 yamaha big bear. He bought it new and only used it around the yard pulling a small trailor. It has sat up in a barn for several years. It is in good condition for its age. I have not had much time to mess with it but i did put some fresh gas in it and it started. I only ran it a few minutes and it ran fine. I still need to change all the fluids. The problem that i found was that it would not move when in high range. Works fine in low range. Any suggestions
Old Apr 10, 2013 | 11:20 AM
TLC's Avatar
TLC
Try holding down the foot brake. If I remember right.
Old Apr 10, 2013 | 03:23 PM
Oldbear's Avatar
Are you sure its actually in high gear, does a light lite up. My thought is linkage or maybe sit on it and rock it with your foot off the brake. Other wise I don't know.
Old Apr 11, 2013 | 11:02 AM
TLC's Avatar
TLC
Make sure the wire to the foot brake lever is still connected.
The only light is red for reverse and green for neutral on my 1989 350 Big Bear 4x4.
95wolv
Sep 27, 2024 12:00 PM
fredrikrosen
Sep 28, 2015 09:58 PM
Clint Russell
Sep 25, 2015 03:20 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
