whats the better setup? prodesign or vetos timing adv.
Old Mar 26, 2001 | 05:45 PM
H300F's Avatar
what setup is better, the vetos timing adv. key or the prodesign timing adv. plate?
How much does the vetos key cost? I think it is cheaper than the 90 to 100 dollar plate.
Are there any probs. with the vitos key? I heard shearing.
What would you recommend to me? I am buying either or really soon...
Old Mar 26, 2001 | 07:31 PM
Charles_Banshee's Avatar
I just got the Vito key, and installed it, it was $24.00 plus I bought the $11.00 fly wheel puller. You will need a puller with either PD or Key, and I used a impact wrench to get the bolt off. I tried to remove the bolt with a just socket/ hand wrench, it just turned the wheels ( I have no park brake ) There is not a good place to stop the flywheel from turning. If 4 degree is all you need The Key is cheaper, I guess the pro-design would be nicer if money is no object.
I used loctite on the nut , just in case.
Charles
Old Mar 26, 2001 | 07:34 PM
Also I order online at
http://quadstore.com/sys-tmpl/door/
and got in less than a week
Old Mar 26, 2001 | 10:14 PM
scottd's Avatar
If you want ease of adjustability, go with the pro design plate. You can vary your timing over a wide range, and do so without pulling the flywheel off again. Also, no chance of shearing. It is a quality piece, well worth the money. You get what you pay for!
slowgsxr97
Mar 18, 2022 03:40 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
cornermike
Jul 8, 2015 11:44 PM
