Warrior 350 noisy starter
Old Nov 9, 2013 | 05:17 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
the cranking sounds fine but i would check your valve clearance, does sound like a more than normal ticking
Old Nov 9, 2013 | 08:12 PM
ducato68's Avatar
Yeah, I was planning on doing the valves, have just done oil/filter, no shiny bits in the filter luckily!! It is 10 times louder in the video tho...not sure why.
Will try and find the specs for the valves.
Cheers for all replies!
Old Nov 9, 2013 | 10:13 PM
sr.ruedas's Avatar
Originally Posted by ducato68
The noisy starter does not come up on video as loud as it does here unfortubately, but you still get to hear the thud at the end.
One of my 2 warriors had the loudest starter I ever had, esp when you
shut it off. Way louder than yours. I did not do anything about it.
I would not worry about it.
Old Nov 10, 2013 | 06:00 AM
Cold
ex 0.16 - 0.20 mm
in 0.06 - 0.10 mm
Old Nov 10, 2013 | 10:24 AM
  #15
ducato68's Avatar
Cold
ex 0.16 - 0.20 mm
in 0.06 - 0.10 mm
Thank you very much for that info, appreciated! Will do them on my next days off.
Old Nov 10, 2013 | 07:45 PM
  #16
papa hogg scoot's Avatar
Loved
Community Favorite
Like said in the above..Thats not enuff to worry bout ...Sounds normal for an warrior like said before.The 660 raptor had an bad decompressor on camshaft that cause there problem..BUT your warrior just ride an not spend an dime on this problem yet.I would adjust values and cam chain is loose thats what I would focus on as of right now.Thanks for the vid
akguy31
Aug 31, 2019 04:34 AM
flyin-lowe
Dec 1, 2017 03:18 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
Bernhard
Sep 25, 2015 12:45 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
