carb jeting
Old Jan 5, 2014 | 08:50 PM
sgill's Avatar
Question carb jeting
hi i have a 2002 raptor 660r i recently rebuilt the carb and added a DG RCM II Black Slip On Exhaust w/ Spark Arrestor. the quad ran great befor i put the new exhaust on. it pops and backfires alot now i have to run it with the choke on or it will stall and if i let off the throttle it will stall iv read alot of stuff and it all ses that my jets are not the right size. when i rebuilt it i did so with stcok jet size.
if i need bigger jet can any one tell me what size i need. its a double bowl if you need any other info please ask
Old Jan 6, 2014 | 10:42 AM
michaelh6's Avatar
if you get a stage 1 moose jet kit should fix that
Old Jan 6, 2014 | 04:16 PM
sgill's Avatar
will these work
Dynojet Kit Dyno Jet Yamaha Raptor 660 01 05 Free SHIP | eBay
Old Jan 6, 2014 | 11:35 PM
michaelh6's Avatar
that should do it
Old Jan 7, 2014 | 05:19 AM
sgill's Avatar
awesome any recommendations on jet size?
Old Jan 7, 2014 | 06:14 PM
sgill's Avatar
my elevation is 451 ft.
Old Jan 8, 2014 | 04:52 AM
The power band man's Avatar
Stop riding it, you are showing signs of a lean condition
Your will roast your head if you keep riding
Start with 2 sizes up on main and 1 size on pilots minimum but you might even have to go higher on the mains. They are cheap you can buy them from Vito or at your locale race shop. It's good to have extra big and smaller jets on hand,to adjust for temp changes if you ride all year long anyway
I can help you but I need to kno what jets are in the carbs. Now?
Do you know how to plug chop? It will help you dial in your jet perfectly
Also take the lid off the air box and are you using premium fuel. You should be.
Make sure your bowl heights are set right when you take the carbs apart to check.
Also check to make sure your spark plug is not fouled and clean.
Old Jan 8, 2014 | 06:00 PM
sgill's Avatar
these are the spec for my carb from the manual
i do not no how to plug chop nor have a heard the term before
i was told there was premium fuel in it when i bought it.
and i just ordered this plug 1 NGK IRIDIUM IX SPARK PLUG DPR8EIX-9
Main jet (M.J) Carburetor #1 : #140 Carburetor #2 : #145
Main air jet (M.A.J) #130 ---- Jet needle (J.N) 5ND16-56-3 ---- Needle jet (N.J) P-6M (#826) ---- Pilot air jet (P.A.J.1) Carburetor #1 : #80 Carburetor #2 : #150 ---- Pilot air jet (P.A.J.2) 1.3 ---- Pilot outlet (P.O) Carburetor #1 : 1.0 Carburetor #2 : 0.9 ---- Pilot jet (P.J) #22.5 ---- Bypass 1 (B.P.1) 0.8 ---- Bypass 2 (B.P.2) 0.8 ---- Valve seat size (V.S) 2.0 ---- Starter jet (G.S.1) #95 ---- Starter jet (G.S.2) 0.5 Throttle valve size (Th.V) #80 ---- Float height (F.H) 13 mm (0.51 in) ---- Fuel level (F.L) 3 ~ 4 mm (0.12 ~ 0.16 in) ---- Engine idle speed 1,450 ~ 1,550 r/min ---- Intake vacuum 32.0 ~ 33.3 kPa (240 ~ 250 mmHg, 9.45 ~ 9.83 inHg)
Old Apr 10, 2014 | 01:07 PM
Luke Webber's Avatar
he didnt want to help huh??
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
