piston slap
Old Apr 1, 2001 | 11:10 PM
jacob14's Avatar
its been gettin about the same, but im not sure because i havent really thought much abotu it till now, when the rpm's go up, the noise doesn't get louder or anyhthing so that good to know, so do you think its time for a new piston and all the stuff, its only a 99 blaster so its not old or anything
Old Apr 2, 2001 | 04:25 PM
99blueblaster's Avatar
The blasters counter balancer does cause quite a bit of noise in the litter air cooled 2 stroke. If you here it when you rev it up and when the motor slows down it could just be the counter balancer. Nothing to worry about. The blaster motor is noiser than most also.
Old Apr 2, 2001 | 05:39 PM
jacob14's Avatar
how can i check this, i don't wanna take my cylinder out cuz i don't want take it off the rod and all that stuff, if i take the head off, will i be able to tell if anythin is wrong, i am thinking about jsut giving up and having someone put in a new piston but if i did have piston slap, would my cylinder be messed up at all in the inside
Old Apr 4, 2001 | 12:33 AM
jacob14's Avatar
coem on guys, in need of help
Old Apr 4, 2001 | 01:34 AM
  #15
DieselPro's Avatar
If you do a piston, bore and hone it for an OS piston. Cost will be little more, and you will have a fresh, round, true bore to which the rings will properly seat, and piston/wall clearance will be correct.
Try Powroll, as they use QUALITY pistons that can be fit closer minimizing slap/rocking etc resulting in a much better performing engine.
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
