1992 Big Bear 350 4x4 carb adjustment
Old 01-16-2014, 12:51 PM
bigbear350quad's Avatar
Default 1992 Big Bear 350 4x4 carb adjustment
Hi,
Can anyone offer advice please?
I have overhauled the carb - Mikuni - all parts renewed, the quad started first time, which was a big releif! However once warmed up the engine is loosing power and won't idle. My question is this, when hot is the carb set too rich? If so is the mixture adjustment the screw/jet on the underside of the bowl? Any suggestions on a good starting point for adjusment would be great
Old 03-02-2014, 06:48 PM
gangle04's Avatar
pilot fuel screw is dead center, head side in front of float bowl, set your idle high enough it will run then adjust the screw in (if it raises idle keep going) if not try out witchever raises the idle keep going that way should be between .5-3.5 turns out from seated gently in. turn idle screw out as the idle is going up untill it will idle properly, it does sound like its to rich to me a way to check is get it up to operating temp, partially cover the intake, if the idle raises its lean, if it dies or starts to sputter it probably rich and you should screw your pilot screw in......hope this helps
Old 03-03-2014, 01:26 AM
Thanks, thats really helpful, tony
Old 03-03-2014, 09:22 PM
gangle04's Avatar
no problem post if it fixes your problem or not
bzdok1234
30
02-23-2016 01:55 PM
tweeder
07-05-2015 01:57 PM
bzdok1234
Utility ATVs
07-03-2015 05:32 PM
robj
06-15-2015 08:45 PM
Joe04785
06-15-2015 03:12 AM
Quick Reply: 1992 Big Bear 350 4x4 carb adjustment
