Help!! No spark
Old May 10, 2014 | 05:00 PM
kenyanfro's Avatar
Default Help!! No spark
My 1990 big bear was running perfect the other day and then just stalled. I started it again drove a bit and stalled again and would not start so I towed it home and now no spark. I.can't figure put what's wrong all lights come on but will not give spark. Any help is greatly appreciated.
Old May 10, 2014 | 07:40 PM
thomtwo's Avatar
Read my post, "Suddenly No Spark 1994 Kodiak" this could be your trouble as well.
If you have a Service Manual go through all the 'Electrical Tests'
Hopefully it isn't your 'Stator or C.D.I. unit. They're expensive.
You can probably buy another older Big Bear for what the OEM parts cost.
Old May 12, 2014 | 09:23 PM
kenyanfro's Avatar
Well I just tried a different coil and plug wire and cap with no luck. Any suggestions on what else to try
Old Jun 9, 2014 | 07:00 PM
25grizzlyrider660's Avatar
check the kill and ignition switch's with meter, if good checks three prong stator plug with ohs meter as well.my stator has .06 ohs on all three pins.three white wires on rectifier need to be checked as well.
fordfaithful21
Dec 7, 2015 05:52 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
