timberwolf stator
Old Jun 9, 2016 | 08:40 PM
tm67chev's Avatar
Default timberwolf stator
I have a 1998 timberwolf 250. When it was shut off last time it was running. Now it has no fire. I've been checking things but now am to the stator. when I opened the side cover I found the stator had some oil on it and some in the side cover.Is it supposed to have oil in the side cover and if so how much? Can't find anything about it in the manual. No, I am not a mechanic. Any help will be appreciated.
Old Jun 10, 2016 | 02:25 AM
Most motorcycle and quad alternators run in oil. Also most of the "big four" makers quads will run OK with a burnt out stator, until the battery goes flat. If you have the electrical skills to test the components, get a manual and go through the electrical checks.
Old Jun 10, 2016 | 06:50 AM
tm67chev's Avatar
Thanks merryman for the info. I can find no info on how much oil is needed. I will try to contact Yamaha to see if they can help.
Old Jun 10, 2016 | 10:17 AM
Fasteratv's Avatar
The only oil required is the correct viscosity and quantity engine oil. This quantity is most likely stamped into the engine case near the oil fill hole.
Old Jun 10, 2016 | 03:07 PM
tm67chev's Avatar
Thanks. Finally got in touch with someone at Yamaha today. They said the same thing. Thank you for your help.
GeoJack
Jun 13, 2016 09:06 AM
Rkskaas
Jun 10, 2016 02:57 AM
USCGMisfit
Jun 4, 2016 03:03 PM
boler76
May 16, 2016 10:55 PM
