02 Ya. Bear tracker, 250 please help
Old 03-30-2017, 07:54 AM
TJFJR's Avatar
Default 02 Ya. Bear tracker, 250 please help
Was running fine, then burned the CDI box, installed a new one, idled fine for 20 min. Gave it some throttle, the R and N light started flashing, back and forth, RNRNRN, then the new CDI box burned up, I'm completely lost, any ideas?
Old 03-31-2017, 02:30 AM
Probably the voltage regulator was overcharging and has slow cooked both CDIs. ALWAYS check the wiring to the CDI before fitting a new one. The earth wire must be earthed or it will blow the CDI. Then when you get the new CDI on and the bike running, first thing to do is check voltage across the battery, if it goes over 15v stop the engine and change the regulator or it will burn out the new CDI.
Old 04-03-2017, 04:25 PM
TJFJR's Avatar
Default Thanks merryman
I wouldn't exactly call it a slow burn, it was very quick, fine until I gave it throttle, then pop.
Old 05-19-2017, 08:47 PM
TJFJR's Avatar
Default Merry man?
I replaced the voltage regulator, and CDI, now the reverse and neutral light both stay on, I'm scared lol. Your thoughts?
Old 05-20-2017, 02:52 AM
Check the earth leads, on a Yam they can look fine but not be. May be time to get a manual and check the wiring using the diagram.
Old 05-20-2017, 06:59 AM
Ajax's Avatar
Did you check the charging voltage at idle after the new voltage reg was installed?
And for sure clean and check all grounds.
A multimeter and a manual will go along way on trouble shooting.
Old 05-20-2017, 05:48 PM
TJFJR's Avatar
Default Voltage
Yes it stayed just over between 13/13.7 volts
