Removing Warrior Parking Brake?
Ok, here is how I did it. I took off the parking brake, the cable, and the parking break part off of the rear brake caliper. I also removed the switch cable that plugs into the perch on both ends, at the perch and at the end where it goes to the parking brake. I have no problems at all. I put a cr250 clutch perch on it and it also shifts much easier.
