04 yfz450 brake hub stuck on axle
Old 01-07-2018, 09:15 PM
Matt Neikirk's Avatar
Default 04 yfz450 brake hub stuck on axle
Alright I’ve got a 04 yfz450 an I need to change the carrier bearings. But I can’t get the brake hub to move at all any help is appreciated.
Old 01-17-2018, 05:39 AM
SAshton's Avatar
I just went thru this in my raptor. The 2 nuts were also very challenging. I used heat, lots of Pb blaster and I destroyed my rotor because I used that to hammer on. I even used a cutoff wheel and removed part of the hub all the way around and was very careful to not gouged the axle. It took hoirs of hitting to remove that hub but I got it. Good luck. I hope yours isn’t as rusted tigjt as mine was.
Entomber
04-01-2008 02:43 AM
R00ST
03-17-2008 04:51 PM
Andy Bassham
08-12-2001 06:02 AM
Quick Reply: 04 yfz450 brake hub stuck on axle
