Raptor 350 question
Old Mar 19, 2018 | 08:30 AM
YamahaMoto's Avatar
Country Rider
Default Raptor 350 question
Hey everyone!
So one of my quads is a raptor 350. So It starts up pretty well and I can start riding. However, randomly while riding it will just stall. When I am riding, sitting still, to hitting the throttle, it stalls. This part of it sounds like a pilot jet in the carburetor to me.
However, if I hold in the clutch, its perfect! I could sit there holding in the clutch forever and it would never stall. This would have nothing to do with the pilot jet. Some reason it runs a ton better with a new spark plug too (This really confused me).
So what does everyone think the problem is?
Old Mar 19, 2018 | 09:21 AM
Jered651's Avatar
I would check the carb give it a good cleaning install a new inline fuel filter and only use non exegenated gas and see what that does for you
Old Mar 19, 2018 | 09:37 AM
YamahaMoto's Avatar
Country Rider
Thanks for the reply. Not that long ago I had someone rebuild the carb and I replaced the fuel line. I also only run rec. gas.
Ill wait for other reply/ do more research but thanks.
Old Mar 20, 2018 | 03:49 AM
When new to mending quads, I had an Arctic Cat that would come in non running, and would be back to normal once I fitted a new plug. Did it several times before the owner said "it runs better with the lights on." I then checked the battery voltage with it running and found the voltage regulator was overcharging, about 18v if I remember rightly, so ever since, if I get a "faulty plug" I always check the voltage to ensure overcharging isn't causing the plug to cook itself.
Old Mar 20, 2018 | 07:35 AM
YamahaMoto's Avatar
Country Rider
Thanks for the reply. I have never tried it with the lights on. Im going to check into what you said. What is the best solution to this problem?
Old Mar 21, 2018 | 04:10 AM
Check voltage across the battery with engine running, if it goes over 15v you need a new voltage regulator. If it stays between 13v and 15v your problem is elsewhere.
Doesn't matter if the carb was rebuilt recently, if dirt gets in, it will need cleaning out.
Old Mar 21, 2018 | 08:06 AM
YamahaMoto's Avatar
Country Rider
Thanks for the help. I will see if I have time to test it tonight.
Old Mar 21, 2018 | 06:25 PM
YamahaMoto's Avatar
Country Rider
Hey. So I tested the battery first while it was off and it came to 11.6V (and its a 12 volt battery). So I started it up and it settled on 14.2 volts. Does this mean that part is ok?
If so, would that mean that it is a carburetor problem then?
NCguy84
Jul 23, 2006 01:24 PM
FERGY450
Feb 14, 2005 08:38 PM
AzRaPt0rS
Nov 13, 2004 12:03 AM
