Wheels
Old Apr 28, 2018 | 08:20 AM
JonSchwab's Avatar
The Wolverine
Default Wheels
I’m purchasing new rims and tires for my Wolverine and I want to make sure that there wouldn’t be problems with them going together(I’ve never bought atv wheels) will 10inch wide tires be okay on 8inch wide rims?
Old Apr 29, 2018 | 07:36 AM
hydrex's Avatar
More importantly, measure clearance inside the stock tires to suspension components. Make sure the rims have the same off set as stock ones, or you might have to run spacers. Use a torque wrench and recheck torque after a few miles, I 've had lug nuts loosen on aluminum rims. 8" is the width at the bead/rim, 10 wide tire should be fine.
Old Apr 29, 2018 | 08:22 AM
JonSchwab's Avatar
The Wolverine
thank you! I will do that! That helps quite a bit!
xlr177
May 23, 2008 06:11 PM
Limp400Korn
Oct 9, 2001 10:44 AM
TxDoc2
Dec 5, 1999 02:59 PM
