2014 Grizzly 350 rear brake
Old Sep 6, 2018 | 09:44 PM
koliver811's Avatar
Default 2014 Grizzly 350 rear brake
Quick question about the nut that holds on the rear brake drum. It appears to have some sort of tab pressed into the rear axle ??? I am used to seeing a nut with a cotter pin. Do I need some special tool or just pry up the tab? Thanks in advance for the help
Old Sep 7, 2018 | 02:29 AM
No idea, Yamaha are weird when it comes to rear brakes, they don't seem to settle on any design. They had discs, then drums, then hydraulic discs, then drums again, then discs, then wet brakes inside the rear diff, then back to discs, so if they went back to drums for 2014, I haven't come across them. A picture of what you have may help.
Old Sep 7, 2018 | 05:35 AM
koliver811's Avatar
Here is a pic of the nut that I need to remove
Old Sep 7, 2018 | 06:38 AM
Jered651's Avatar
That is a 1 time use nut buy a new one. That nut takes the place of a tab washer after torqueing the nut you take a punch and bend it down in so the nut cant back off. To get it off you can use an impact or bend it out and remove
Old Sep 7, 2018 | 10:35 AM
koliver811's Avatar
Thanks for confirming what I was thinking !
Old Sep 7, 2018 | 12:09 PM
Jered651's Avatar
you bet good luck they can be a pain without an impact.
DH91679
Sep 2, 2014 11:48 AM
nickyg20
Apr 2, 2014 07:44 PM
reconrider88
Jul 17, 2013 09:27 PM
