Kodiak 450 need help
Do some research on the oem parts list. see what parts on the head interchange you might get lucky and find raptor head or parts interchange and you can use an entirely different head. You can put a warrior head on a big beat 350 but its not the same the porting is different for better air flow. When I rebuild big bears I always put 10.25-1 piston and a warrior head on Gives it some good bottom end and will also handle the accelerator pump from a warrior carb.
