Kodiak 400 sputters bad
Old Feb 28, 2020 | 08:09 AM
Monte952003's Avatar
Default Kodiak 400 sputters bad
Have a 200 Kodiak 400 starts and idles fine when you give it throttle it sputters and wants to die put brand new carb on and it's gotten worse what else should I check before I start to just throw money at it?
Old Feb 29, 2020 | 02:40 AM
Fit a new plug. Check with a voltmeter across the battery, that voltage from regulator, with engine running/revving, does not go over 14.5v. Clean the jets in the old carb out with compressed air and put that carb back on. If none of these work, get the workshop manual and start checking ignition system for faults.
Brett Boisvert
Mar 11, 2019 08:53 PM
Johntom2000
Apr 23, 2013 10:41 AM
FastbansheeandKodiak
Utility ATVs
Feb 25, 2004 11:44 PM
cigardude
Oct 31, 2002 03:53 PM
