Warrior sputtering at 1/2 throttle to WOT
Old May 24, 2020 | 02:22 PM
Salas30's Avatar
Default Warrior sputtering at 1/2 throttle to WOT
Got a 2000 warrior 350 couple months ago was running perfect until about a month ago. Every time I ride and go past 1/2 throttle it starts to sputter/ backfire like something is stopping it from going. I have changed spark plug, coil, got a brand new out of the box carb, rocker arm adjustment, checked green ground on foward/reverse lever, new fuel filter, checked fuel lines and fuel seems to flow good, I already had the parking brake wire off so it’s not that. I’m currently ordering a stator to see if that’s the problem but wanted to see if anyone has had this issue before I start buying unnecessary parts. Anything helps thanks.
warrior338
Jul 5, 2008 08:03 PM
Kaldir
Jan 2, 2008 10:37 PM
chargedstang89
Sep 8, 2004 01:15 AM
crankase
Sep 29, 2002 10:04 PM
mtbdad
Nov 25, 1999 01:52 PM
