Old bear tracker vacuum line help
Old Aug 1, 2020 | 07:24 AM
  #21
Dad2daz3's Avatar
Default Back again
Thank yall for all the help I could not do this without it. I haven't been able to get a compression gauge all the auto stores don't have one that fits. But if you put your thumb over the hole it definitely has force blowing out and drawing it. Hope this helps. David
Old Aug 2, 2020 | 02:14 AM
  #22
If it has any compression you have probably "got away with it" not bending a valve. Buy the workshop manual and set the cam timing up with that. It will tell you how to check for a stretched chain, and a broken/seized adjuster. Make sure the chain guides are in good condition and fitted properly.
Old Aug 2, 2020 | 10:41 AM
  #23
Dad2daz3's Avatar
Thank everyone so much there's know way I could have work on my son's atv without yalls help. This is the best atv forum out there and the best people. I've got some parts ordered and I'm going to try to put this thing running with yalls help. Thank y'all so much. David
Old Aug 4, 2020 | 04:58 PM
  #24
Kymco 450i's Avatar
Take the time to do it right. Getting into a big hurry and screwing it up will only cause your son to loose interest. Should make a great father - son bonding experience!!
Old Aug 14, 2020 | 10:36 PM
  #25
Dad2daz3's Avatar
Bigger problem. Was getting ready to start to work on replacing the timing chain. And i found that the camshaft sprocket is wobbly. So wobbly that I can't get the sprocket off. How do I get this thing out or what should I do? Thank yall. David
Old Aug 15, 2020 | 02:52 AM
  #26
Drawing shows a single bolt holding sprocket to cam, remove bolt and washer, pull sprocket from cam. If it is stuck on, use some sort of puller on it, being careful not to damage end of cam.
Dad2daz3
Jun 19, 2020 10:47 PM
JAMIEZ71
Jul 3, 2008 09:35 AM
jteach
Mar 14, 2005 11:11 PM
Rackman
Sep 29, 2003 11:04 PM
