2000 Kodiak carb? timing? electrical? issue
Old Jul 21, 2020 | 05:54 AM
gd2227's Avatar
Default 2000 Kodiak carb? timing? electrical? issue
I've been trying to sort this out. Bike starts and idles fine. As soon as I open the throttle, it pops/ backfires through the carb.
-No vacuum leaks- checked w/ starting spray while running
-New boot
-Carb is clean and original
-Timing is on the mark
-Timing chain is tight- no play
-Valves are adjusted to factory specs
-Cam has clean lobes
The original CDI burnt out, and I replaced it with a factory CDI (those aftermarkets did not work.. so, $300 later...).
IF the neutral switch/ sensor has failed, would it cause the CDI to go into "limp" mode? As the neutral light on the dash doesn't light up when in neutral. Plus, I cannot start the bike in neutral... It almost seems like it's running in a "limp" mode, where it's cutting out spark (although when it pops out the carb, fuel is spraying out of the carb).
Interestingly, every now and again, I can catch it where I can get it to rev to a high RPM without popping for a few seconds.. then it begins popping again..
I am stumped. I took it to 2 shops and they have failed to figure out what it is...
Old Jul 22, 2020 | 02:46 AM
Check the voltage at the battery with engine running, if it goes over 15v it may be cooking your CDI. Always do this after fitting a new CDI and, before fitting one, check all wires to the CDI are working correctly, particularly earths. There is obviously a problem with the ridiculously over complicated neutral "lock-out" system, fix it. The poor running could be a blocked exhaust, try it without the silencer.
Superduty01
Sep 11, 2013 08:25 AM
