Warrior engine case welding
Old Sep 9, 2020 | 09:08 AM
Jmpwarrior's Avatar
Default Warrior engine case welding
I had my chain drop on my warrior and balled up at the front sprocket. Resulting in breaking off the holding mount for the chain guard. I was hoping that this could be welded. Anyone been able to successfully weld on these cases? Or should I just look for a used case?
Old Sep 10, 2020 | 02:55 AM
I have had Honda cases successfully welded by TIG specialist welders. Also think I would be finding an alternative way of mounting the guard before looking for a used case.
Old Sep 10, 2020 | 08:28 AM
Jmpwarrior's Avatar
Unfortunately the mount broke in a way that it compromised the case with a hole. Good to know it can be welded. Thanks for the input.
Old Dec 30, 2020 | 10:34 PM
Michael Horsford's Avatar
I have a warrior same thing someone used epoxy to cover a hole the size of a quarter but they did a good job it doesn't leak . I've since used my dremel to make it look more even and natural but so far no problem in its been on there a long time .... My advice try it you aren't outta much if it doesn't hold ... Just make sure that area isn't smooth & the epoxy has something to really bond with ... The guy used some 2 part that was made for Anthony crane where he worked at some point .... Im sure theres gotta be good epoxy possibly grainger ? ... Good luck
sansabar
Feb 11, 2008 09:05 PM
OutlawSS
Mar 28, 2007 10:31 PM
Warrior350ripper
Aug 14, 2004 07:56 PM
