TEch HElp with 83 Tri-Moto 200
Old Oct 13, 2020 | 10:08 AM
robinsoss's Avatar
Default TEch HElp with 83 Tri-Moto 200
I have 1983 Tri Moto 200EK (Shaft drive). It was a little hard to start and kicked back sometimes when starting with the recoil. I broke down and replaced the starter clutch so I could start it easier. It hasn't helped. Here is what is happening and hope someone has some ideas:
1. It tries to start. Hit the start button it fires and sounds like it will go but dies almost immediately.
2. If I give it even a little throttle while starting it dies and kicks back.
3. I was able to get it going 1 or 2 times since starter clutch replacement but takes forever. Ran great once started.
Things I have done.
1. Cleaned carb and adjusted everything to spec.
2. Checked that flywheel and cam gear are aligned at TDC on compression stroke
3. Adjusted cam gear tensioner to spec
4, Adjusted Intake and exhaust valves to with-in spec (they were already but tried to open intake a tad but didn't help)
The plug gets almost immediately black just trying to start it.
I have not checked compression yet (tester is at the cabin) but I will. Given that it did start and run I am thinking compression is at least ok.
I also still need to hook a timing gun up and check timing but since I can't get it started don't think I can check it. Also there doesn't seem to be a way to adjust timing anyway.
Anybody have another idea?
Old Oct 14, 2020 | 03:36 AM
Check the TDC mark really is at TDC by the piston. Rare for it not to be miles out if the flywheel key has broken and timing slipped, but since I guess you have had the flywheel off to fix the starter clutch...
If it is wrong, you will now have set the valve timing to the wrong setting too.
Old Oct 14, 2020 | 09:38 AM
robinsoss's Avatar
I was able to check compression last night and it is in the acceptabe range for this bike (122). I took the carb off again and I do notice very tiny particles of dirt in the float bowl even after cleaning. I am going to replace fuel line and put in an inlign filter downstream of the peacock screen filter just in case. Maybe the dirt is blocking air flow and preventing clean combustion. If that fails I will pull side cover and flywheel off and check TDC is actually TDC. Although I think it is close because the valves are loose only when the TDC mark is showing in sight window. Thanks for the suggestion.
8up4wheel
1) Engine problems..
Aug 25, 2020 02:57 AM
Robpal
Jul 16, 2020 01:48 AM
