wolverine has no juice
My son backed it out of the garage and turned it off ..now i can turn the switch on and have no neutral light ..headlights do not come on ..it has lost connection to everything.. somebody please help
Check the battery has not gone flat, various reasons why it can, dud battery or faulty voltage reg are two. If the battery isn't flat, it has probably blown the main fuse, on most Yams this is on top of the solenoid. There will be a reason for blowing, again faulty regulator is the most common but a wiring fault causing a short could be the culprit. Always test stuff before changing it though, so don't just buy a battery or regulator and hope, test the wires to them. As it did it while being stored, rodent damage to the wiring is another possibility.
