1994 Yamaha Moto4 350 only runs with choke applied.
Old May 1, 2022 | 11:59 PM
ktay72's Avatar
Default 1994 Yamaha Moto4 350 only runs with choke applied.
I replaced the carb on my moto4 and it will only run with the choke applied with it off it will back fire some and then it will rev up really high randomly and then idle down and die. Sometimes I have to kill it for fear it’s not gonna idle down. I’ve messed with the air fuel screw quite a bit and it doesn’t seem to do anything for it.
Old May 2, 2022 | 03:04 AM
Seems a bit like a cracked inlet manifold. Yams are prone to this and the most likely time for it to let go is when you have been pulling at it to get the carb off.
Old May 2, 2022 | 09:26 PM
ktay72's Avatar
I just checked and it does not appear to be cracked. Upon further checking though I may be an idiot. I forgot to put the o-ring between the carb and the inlet manifold. Now I have to find where I put the box with o-ring lol. Thank you so much for the help though once I find the o-ring or get a new one I’ll update on if that helps.
warior6767
Mar 3, 2014 09:14 PM
wildwest1011
Nov 12, 2006 11:40 AM
fastquad02blaster
Jan 2, 2006 11:08 PM
WolfRider
Sep 14, 2005 01:29 AM
rickytz7111
Apr 16, 2004 10:04 PM
