1999 Yamaha Bear Tracker
Old Jul 16, 2022 | 08:05 AM
Ddun's Avatar
Default 1999 Yamaha Bear Tracker
Hi this is my first post i bought a 99 bear tracker a few months ago, it was running fine till one day in the trail it started to sputter,backfire and lose power. So replaced the carb but then i couldnt get a spark so ordered a cdi as i was told that could be the problem, so the bike would not start at all, i was out trying a few things so i put the old cdi back on it, still nothing so i believe i read something about the ignition switch, i unhooked the ignition switch and pulled it over started rite away but still loses power at half throttle and sputters. When i plug the igniton switch back in while she is going it immediately dies any ideas on what steps i should take to rectify this problem would be greatly appreciated Thanks.
Old Jul 17, 2022 | 03:15 AM
The CDI is independent of the battery system, so needs a kill wire to stop it sparking. This is wired through one half of the ignition switch and earths the kill wire when you turn ignition off. So, looks like the switch is faulty and is still earthing the kill wire when ignition is on. Make sure if it is the ignition switch, or kill switch, that is faulty, as it could be either, then get a new switch. Clean your old carb out. Remove and blow through jets and the holes they came from, with compressed air. Do not alter needle settings. Put it on bike, and see if mid range stutter has gone.
Old Jul 17, 2022 | 09:05 AM
Ddun's Avatar
Thanks for the reply i have replaced the ignition switch electric start works again now but i am still losing power so i guess its back to the carb will update when i get back in a couple weeks thanks for the info
Riley12051998
Dec 2, 2021 05:33 PM
moto4guy
Jun 2, 2019 08:16 AM
Searatt1
Mar 6, 2018 12:29 PM
davedamex
Jul 4, 2011 09:31 PM
