2001 Kodiak mods
Old May 3, 2001 | 07:55 AM
wolv09's Avatar
What are your mods for the kodiak and what improvements did you notice?? Mine is stock only mod done so far is itp wheels and blackwater tires
Old May 3, 2001 | 10:04 AM
KISSSOFDEATH's Avatar
My tires and snorkels so far.
Old May 3, 2001 | 10:49 AM
bluekodiak's Avatar
First mod was the Mudbugs, good investment. Next was the K&N filter and jet kit, this made a noticable difference in power. Turns the bigger tires no problems.
Old May 3, 2001 | 02:31 PM
MudFish's Avatar
Go with a new clutch kit...put a Grizzly clutch in mine, works great on low end. A rejet and pipe would definately add some zip to it. Am putting 1 1/2 inch spacers all the way around to give mine some stability. Was going to put some 26 or 27 inch tires on it, but I picked up some once used 25 inch Vampires for $40 apiece...friend tore the back end out of his polaris, so he ditched the tiresgood for me!!!!
Old May 3, 2001 | 03:09 PM
FKNA's Avatar
Best mod I made to the Kodiak was putting on the Goodyear Mudrunners. Second best mod I made has putting a snorkel on for the carb. Since I LOVE to night ride, I put on directional lighting for the handlebars, which is a must.
Since you have larger tires on it, you'll definitely will want a clutch kit. You see a difference right away.
Old May 4, 2001 | 07:54 AM
wolv09's Avatar
Where did you all find a clutch kit and how hard was it to install and what did it do for you second what improvements did you see with the ids2 pipe Thanks
Old May 4, 2001 | 01:35 PM
MudFish's Avatar
Check out http://www.highlifter.com/store/ for the pipe and clutch kit. You might be able to get it cheaper elsewhere, but you can at least get the part #'s. Highlifter is real good about answering questions. so give them a call. A friend of a friend put my clutch kit on, so can't help you with how difficult it was.
Old May 5, 2001 | 03:41 PM
FKNA's Avatar
The hardest part about installing the clutch kit is getting that one clutch nut off due to the free spinning of the clutch. This is easily overcome though with an impact. I personally think the price of the clutch kit is outrageous. All it consists of is stainless steel tubing cut to the appropriate lengths. If I had it to do over again, I would of made my own....On the bright side, you WILL see a noticeable difference once the clutch kit is installed.
Old May 6, 2001 | 08:55 PM
wolv09's Avatar
bought a used pipe ids2 for 140.00 and it was set up at adealer with 8 discs in it so you dont need to rejet made a big improvement The clutch kits everyone is installing does it raise the engagement rpm like that of a snowmobile also has anyone tried an aftermarket filter (air) and what were your results
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
35dodge
Sep 29, 2015 09:40 AM
Sep 23, 2015 06:23 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
PrairieDog126
Sep 16, 2015 01:33 PM
