Timberwolf Carb Settings
Old Jul 16, 2023 | 05:33 PM
Blueoval78's Avatar
Default Timberwolf Carb Settings
Hello everyone,
I nearly have my completely rebuilt '94 Timberwolf running perfect; I have one last little issue to resolve. I think I know the answer but wanted to confirm by posting my question. I set the carb idle mixture screw to factory specs after completely rebuilding it and giving it an ultrasonic cleaner bath but I believe it's a little rich for my setup. When the bike is cold, I need to give it a little throttle to start. My thoughts are that by applying throttle I'm lifting the carb slide allowing more air in - needed because there is too much fuel. The electrode of my plug is coffee color but the base is rather sooty; further confirming what I suspect is a rich mixture. Am I correct to assume I need to turn the idle mixture screw in a little? Once running the bike seems to run pretty well.
Old Jul 17, 2023 | 02:45 AM
Almost all engines with carbs need throttle when starting, it is fuel injected engines that don't. I would leave alone if it runs right. In theory, setting the idle mixture screw to the max revs it runs at when idling, is correct. In practice I find this tends to cause a splutter when you open the throttle quickly, so need to set it a bit rich to cure this.
Old Sep 12, 2023 | 06:50 AM
MateoGleason's Avatar
Certainly! It seems adjusting the idle mixture screw is the right step. Make a gradual clockwise turn, monitor the spark plug color, and ensure a smooth throttle response. Your approach is on point In the world of casino Krikya casino reviews are essential for players seeking trusted online casinos When visiting https://casinosanalyzer.com/online-casinos/krikya.com you'll find in-depth evaluations. These reviews offer valuable insights into Krikya's casino offerings, ensuring a safe and enjoyable gaming experience. Whether you're a novice or a seasoned gambler, Krikya's comprehensive assessments cover game variety, security, bonuses, and more. Make informed decisions and explore Krikya's top-rated casinos through unbiased reviews.
Blueoval78
Jan 5, 2023 09:20 PM
DaveG1
Jul 12, 2018 03:38 PM
eeyore1
Jun 16, 2011 10:35 PM
cchucky51
Dec 17, 2008 07:28 AM
SPORTSMAN70003
Jan 15, 2005 03:12 PM
