Can't get my boot under the shift lever!!
Old May 4, 2001 | 01:36 AM
RoadKillJoe's Avatar
I can't get my size 11 motorcross boot under the shift lever on my Raptor even with the adjustment all the way out. Anyone else out there with this problem? If so, how did you fix it? Are there longer levers or longer adjustment threaded rods available? I asked my dealer but they were no help.
I can't be the only one with this problem!!
Thanks,
Old May 4, 2001 | 01:47 AM
Mudrat454's Avatar
Take it off at the shaft splines and move it around 1 or 2 splines to raise it. The rod is for fine adjustment. I raised mine this way and it works fine with my boots.
Old May 4, 2001 | 09:45 AM
ERICsRAPTOR's Avatar
D*mn Graydon nerfs!! Size 12 boot! I sort of strecthed the inner straps by pushing down but if I were you I do what mudrat454 recommended. Just pull the shifter off and move the front up to where it suits you.
Old May 4, 2001 | 09:54 PM
BlueReptile's Avatar
That's exactly what I did and it worked great!
EIF
Apr 20, 2017 07:15 PM
tysonbully
Sep 28, 2015 02:30 AM
Clint Russell
Sep 25, 2015 03:20 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
