2001 Kodiak 4X4
Old May 15, 2001 | 11:00 AM
NINman's Avatar
When I put the machine in reverse I lose a bit of power. I am afraid that when I put bigger tires on it that I won't be able to back up with enough power. Any ideas. Also my front ends seems a little loose, how do I adjust it? Thanks for your help.
Update: Stearng is still loose, reverse sounds like it is starving for gas. I also seem too think the waterpump went bad. Anyone know where the waterpump is located. If is just under and to the right of the pull start then that is where it is leaking. Going to the dealers soon. Calling tomorrow. I will let you know what is up.
Old May 15, 2001 | 12:06 PM
FKNA's Avatar
There is no adjustments you can make. However, once you put on some larger tires, put on a clutch kit as well. You'll need that for also going forward.
Old May 15, 2001 | 10:34 PM
NINman's Avatar
T
Old May 16, 2001 | 08:11 AM
wolv09's Avatar
in reverse that is the rev limiter all the 2000-2001 kodiaks do the same thing and coolant by the pull starter is definately the waterpump have it fixed asap
Old May 17, 2001 | 03:01 AM
KISSSOFDEATH's Avatar
I got my Kodiak back today from the dealer. He replaced my water pump. It is located where you are looking and you should get it fixed asap. I believe my new pump is different than the old one. This new one has a 7 to 8" clear plastic breather tube hanging down from the bottom. I dont remember that being on the old one. Check yours and let me know what you see. Hopefully Yamaha has finally updated the water pump.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
35dodge
Sep 29, 2015 09:40 AM
jsmit116
Sep 18, 2015 10:34 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
chewy78
Sep 8, 2015 10:37 AM
