Boreing Vs. Milling
Old May 20, 2001 | 03:59 PM
lonestarbanshee's Avatar
Hey everyone, I was talking to a guy at the local track, and he said he got his Banshee milled. I asked him what exactly it meant, and he said instead of being bored, he got it milled. My impression of a mill job was shortening the stroke.. am I wrong?? Also, where is a good place to get an engine rebult? My Banshee is .20 over, and it needs going over again. I'd really like to bump it up to 370, but like Zorro said, it can get expensive. I will be getting some DMC's or, maybe Bill's Platinum. Thanks in advance,
Old May 20, 2001 | 09:57 PM
Warriorcowboy's Avatar
Did he have it done to the head or the cylinder, if it was to the head he probably had it shaved. If it was the cylinder it would shorten the stroke. Unless it was done on a CNC mill then it could be set up to be bored.
Old May 20, 2001 | 11:20 PM
I'm not really sure, but I would imagine it was done to the cylinder. I hate the guy, he's always bragging about how fast his bike is, but.. he's slow.. So, DMC or MotoFast, or maybe Bills?
Old May 21, 2001 | 12:02 AM
ChrisMac's Avatar
You can only Bore a cyclinder which increases displacement or you can mill(shave)your head which increases compression. Or you can bore you cyclinder and shave you head that way you have a few more CC's and more compression!
Mac
Old May 21, 2001 | 10:12 AM
Mudrush's Avatar
you can bore a cylinder on a lathe or a milling machine. If you do it on a lathe you turn the cylinder around and the tool stays still. if you set it up on a mill with the right fixture you jut bore it out like drilling. Either way it increases the bore diameter.
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
