Play in handlebars
Old May 21, 2001 | 01:23 AM
Raptorguy's Avatar
Noticed the other day that I had an half an inch of play in the handlebars when I turn them. Can turn them left and right about half an inch before the wheels actually turn. Has anyone elso experienced this? Possible problem and solution suggetions?
Old May 21, 2001 | 02:00 AM
Mudrat454's Avatar
Check the nut on the bottom of the steering stem! It comes loose and gives you play in the steering. Some people use loc-tite and some have been putting castle nuts on them. I tightened mine up once and it has stayed tight since.
Old May 21, 2001 | 02:43 AM
bigkdwag's Avatar
Believe it or not i was just coming on the forum to ask the same question i just found that out on mine tonight also
thanks for the input i was gonna replace the tie rod ends
thanks again that is why this forum ROCKS
Old May 21, 2001 | 11:28 AM
RaptorMom's Avatar
Had the same problem about 2 weeks after getting my Raptor. Used the blue Locktight and torqued to 65 lbs. I think this is correct but I would check if you have a manual since I was told this by the dealership over the phone.
Old May 21, 2001 | 03:54 PM
chop's Avatar
i had the same problem with my DS.looks like we have one problem in common.
Old May 21, 2001 | 04:09 PM
FourStrokeFan's Avatar
I had the same problem with mine and noticed the nut was a little loose. I tightened it, but for some reason I thought it made the steering harder. Does tightening that nut (or maybe over-tightening it) make the quad harder to steer or was that symptom just my imagination?
Old May 22, 2001 | 01:48 AM
Mudrat454's Avatar
My service manual calls for 80 ft lbs (110Nm) for the nut on the bottom of the stem. I would not think that over tightening would cause it to steer harder, it would just eventually strip the threads(over tightening) cause it appears the pitman arm bottoms on the stem and not against anything on the frame.
Old May 22, 2001 | 09:10 AM
otterbob's Avatar
yup just thought that i would chime in and say the same thing happened to me and also a friend of mines too. seems like it would have come from the factory with a castle nut. just one more thing for my honda riding buddys to crow about.
Old May 23, 2001 | 02:01 AM
AdrenalinFreak's Avatar
If the play is side to side, as in when you start to turn, but it takes a second for the wheels to follow the bars, Check your tierods, I had mine loosen off on my banshee and it did that.. I dont see the play being caused by the nut on the bottom of the stem. That just doesnt make sense.
Old May 23, 2001 | 12:59 PM
Mr45auto's Avatar
It may seem hard to believe that loose nut causes play but I've experienced it myself. Once I tightened it up it hasnt caused any further problems. At least they put a pin at the bottom to keep the nut from falling off.
bmxatv10
Oct 14, 2022 06:23 PM
shimanok2
Jan 29, 2016 07:37 PM
2many2ride
Sep 27, 2015 04:35 AM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
