What kind of Oil?
Old May 22, 2001 | 05:48 PM
BlackIce's Avatar
I was just curious what kind of oil i should use to mix witht he gas for a banshee? Is any 2 stroke oil ok? Or do i have to buy some from a race shop? And if so, what brand? Thanks a lot
Old May 22, 2001 | 08:26 PM
brokemybanshee's Avatar
I'd go with yamalube (R-2 or 2-R cant remember the exact name), its somewhat cheap and it works, never heard a complaint..
Old May 23, 2001 | 01:08 AM
yamaracer5's Avatar
Hey BlackIce,
I have run a couple of different oils in my YZ250 and the best oil i have used is Castor 927.It has that really sweet two stroke oil smell.I also have used yamalube which is alright and i have also used bellray.The castor 927 is kinda expensive but deffinately worth it.
Old May 23, 2001 | 02:02 PM
409LongRod's Avatar
Either Klotz Benoil, or Maxima 927... I have run both in my machine with good results. I would stay away from the yamalube... I have heard it doesn't burn quite as clean...
Old May 23, 2001 | 04:07 PM
WyoRider's Avatar
To be on the safe side, don't buy any oil from Wal-Mart or that type of store. There are several good 2 stroke oils that your local motorcycle shop may carry. Personally, I use Yamalube 2-R and can't complain. Stick with a name brand oil designed for PRE-MIX (some are for oil injected machines) and follow the gas/oil ratio guidelines and you'll be OK.
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Alex G.
Sep 16, 2015 12:13 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
