AC Delco Filter on Raptor
Old May 14, 2002 | 12:45 AM
  #21
Radman's Avatar
I have been useing a Fram filter it is only 1/2 longer than the Yamaha. I don't remember the part #, I will go look tomorrow. It is a perfect fit just a little longer [img]i/expressions/face-icon-small-happy.gif[/img]
Old May 14, 2002 | 01:28 AM
  #22
KNOWSALOT's Avatar
The Facility
LOL......All you guys are running the old supersport spin on by Yamaha which is still available because most cruisers still run them as stock equipment.
There is no difference other than length.
No difference concerning by pass and relief valve. Only the length.
Old May 14, 2002 | 02:03 AM
  #23
14mins's Avatar
Raptorrider- we had a dyno out last week end. Might do it again if some more want to try it out. If not enough intrest me and the boy are headed to kermit, with rod and his son. (rod is still waiting for his custom lonestar crf450, should have his new z-400 by then) If there is enough intrest in the dyno, rod will ride the week end at my place. Let me know. Bob is home.
Old May 14, 2002 | 08:44 AM
  #24
deltadawg's Avatar
What is the filter model or part number so I can pick me up one for myself?
Old May 14, 2002 | 10:23 AM
  #25
garyc660R's Avatar
I have been using a BOSCH 3300 for about 4 months now. It's maybe a 1/4" longer than stock, BLACK, and I don't have too lube it to fit between trees. THis filter is originally designed for a Maxda RX-7 and Miata....same threads as the much longer PF-2057.
Also, that Fram filter that someone posted about using earlier.....it's junk....do a search on that filter (PH6017a). There is a study on the net concerning that filter and conmparables....very interesting info.
Here is a list that I compiled that has the same thread pattern....
FRAM PH6017A (JUNK) about $7 is the same as the following
Motorcycle-Specific Filters - (About 2.5 to 3 inches long)
1. Purolator Motorcycle ML16817 about $6.00
2. NAPA Gold 1358, Carquest 85358, WIX 51358 about $7 to $8
3. AC Delco PF2135 about $10
Automobile Filters - (About 3.5 inches long - fit reference 1994 Mazda MX-3, V-6 Engine)
1. Mobil 1 M1-110 about $10
2. Bosch 3323 about $5
3. Purolator Pure One L14620 about $6
4. NAPA Gold 1356, Carquest 85356, WIX 51356 about $6
5. Deutsch D-370 about $4
6. AC Delco PF-2057 about $6
7. Motorcraft Long Life FL-821 about $4
8. STP S-02867 about $3
Automobile Filters - (About 2.5 inches long - fit reference Mazda RX-7 and Miata)
1. Bosch 3300 about $5
2. NAPA Gold 1365 about $6
3. Purolator L14622 about $5
4. AC Delco PF1237 about $6
5. STP S-02876 about $3
Do some research on these filters and make a determination whether or not too use any of them. I would recommend for everyone to use the OE replacement available at your local shop. I will continue running the Bosch 3300 though....lol.
Old May 14, 2002 | 10:40 AM
  #26
garyc660R's Avatar
<< Raptorrider- we had a dyno out last week end >>
14mins...what were your #'s....did any of the DS guys show up?
Old May 14, 2002 | 05:43 PM
  #27
Raptorrider2001's Avatar
Warrior007-Yes, I am still running the AC Delco #2057. It has been about 15 months now. I have logged about 85 hours on my Raptor. Not a hint of a problem. The filter crosses with one for a 97 Mazda minivan with the V6. Be aware that the same filter in a Puralator brand will not seal and will pour all of your oil in in a very short time. See my earlier post about the Fram filter above. They are not concave enough the clear the large glan nut and the nut will not let it seal against the block.
Old May 14, 2002 | 11:20 PM
  #28
Radman's Avatar
The Fram is a PH 6607 and was about $3 from your local Wal-mart. Now if it was leaking don't you think I would have noticed it?[img]i/expressions/face-icon-small-tongue.gif[/img] It is exactly the same as stock just a little longer. Now as for it being junk, could be. I changed my oil and filter so often it doesn't matter. I would rather have a black one, so next time (real soon) I'll go look for a Bosch[img]i/expressions/face-icon-small-smile.gif[/img]
Old May 15, 2002 | 08:08 AM
  #29
deltadawg's Avatar
Now that we all know we can replace the factory filter with a much cheaper oil filter what about the oil itself? Please include weights and brand.
Old May 15, 2002 | 08:58 AM
  #30
NotuRaptor2's Avatar
I read the articles once before that were mentioned.
The problem with the FRAM filters is not from external leaking that you would notice. It is internal leaking because the glue used to seal the filter material falls apart and allows dirty oil to pass on by without being filtered.
/NotuRaptor
