Mods for a 2001 Warrior
Old Jun 21, 2001 | 04:04 PM
ridnwarrior's Avatar
I have a 2001 Warrior. I was thinking of installing a K&N filter,
K&N jet kit and a White Brothers Pro Meg Silencer. Any suggestions or advice would help.[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jun 21, 2001 | 05:02 PM
2001atv's Avatar
I would suggest getting a Pro Design intake kit. This kit allows you to convert the POS slide in filter to a clamp on. The stock filter is only held to the intake track by a bead of grease and the grove in the box and on the lid. Pro Design sells the adapter by its self or you can get the filter, adapter, and outer wear all in one. The air box lid is a little tight with the outerwear on but the filter is a two stage filter w/o the outer wear.
Old Jun 21, 2001 | 06:35 PM
skikke's Avatar
I have a K&N filter on mine and I like it. It's a very little gain, but noticable if you take the baffle out of the stock pipe. I have had a WB pro meg pipe on order for over a month now. It is on back order in two different warehouses. I would suggest putting a 14 tooth front sprocket on. It makes a big difference in speed, and it makes the shifting feel a little bit smoother. Just suggestions!
Old Jun 21, 2001 | 06:59 PM
WildTurkey's Avatar
Yeah, if you haven't bought the K&N filter yet, DON'T. Get the ProDesign set-up for the clamp on K&N. I haven't had any problems with my "stock" style K&N, but I wish I got the clamp-on kit instead. I just gotta pay good attention when re-installing mine.
Old Jun 21, 2001 | 09:35 PM
If I get the Pro Design intake and clamp on filter can I run without the airbox lid?
Old Jun 22, 2001 | 12:28 AM
01BLASTERJW's Avatar
i would not run with out the lid. even with the lid mine gets alot of dirt in it when i do some hard rideing
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
35dodge
Sep 29, 2015 09:40 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
Sep 23, 2015 06:23 AM
