How to get the Clutch cable out of the stock Banshee lever
Old Jun 29, 2001 | 04:16 PM
RoostKing's Avatar
The Topic says it all. I am going to be putting on a new Clutch lever this weekend and want some tips for getting the end of the cable out of the stock lever. 1 to many rollovers!!!! Thanks in advance,
RoostKing...
Old Jun 29, 2001 | 09:22 PM
Need4Speed's Avatar
Just make sure there's a lot of slack in the cable and then push on it cable so it slides though the slot in the lever. It's not too complicated if ya ask me.
Old Jun 29, 2001 | 10:19 PM
TitanRacing25's Avatar
yeah it's pretty simple must be bent pretty bad
Old Jun 29, 2001 | 11:07 PM
Zorro's Avatar
One good thing to do is to unbolt the lever...then it will be trivial to take the cable off...that's usually how I did...and once it's all apart...grease everywhere!!
Old Jul 1, 2001 | 11:21 PM
lonestarbanshee's Avatar
You probably already did it.. But, take the whole assembly off, unscrew the fastner "thingy-ma-jigger", take the CABLE out of the assembly, turn it bout 90 degrees, where there's nothing holding it back.. and the end should slip right out. If you're going to replace the lever, get the cable too!! Mine broke the other day.. Right in the middle of the track!It sucked.. One other thing, I had to take my right carb off to get back to the clip or whatever it is.. and the air equalizer tube came off, and I didn't know it.. It ran like crap.. if you do replace it all, make sure that tube's back in place!
Old Jul 2, 2001 | 11:15 AM
RoostKing's Avatar
I thought this sounded like a stupid question and after talking to some locals, I knew it was a stupid question. I took a look at my cable again and figured out why it would not just go the 90 degree route and slip out, it was kinda crimped and the piece of metal that surrounds the lead portion would not turn all the way. It took some work, but I finaly got it to come out, but jacked up my cable in the process, which is ok I suppose since i was pretty stiff at any rate.
Thanks guys and gals,
RoostKing...
Cole Hadden
Jun 15, 2025 09:05 AM
Polarisman1123
Aug 3, 2015 02:08 PM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
